G-Force meter
dsmless
tucson,az
my friend at work has a g-force meter its spose to measure your hp and tq as well as do 1/4 mile time and speed, 60 foot times and skid pad g's, we used it on his brohters 16g turbo civic, it says it put down 285 hp which is 5hp off from the dyno sheet, so we tryed it in my vr4, four guys half tank gas some tools in the trunk, did a 1, 2 gear pull like said and it said i put down 413 hp, this sounded to high but did it again and put down 416 hp, did a 1,2 and had to cut 3th short due to a car getting in the way and it said i put down 387hp then had to reset the meter, so im kinda lost, i think my setup is pretty conservative just running a gt2876r at 22 psi 91 pump gas 650, 2g maf, and a keydiver chip, the motor is built but head and cams are freshend stock, so does this sound right or is this meter wackey, well thanks guys
The Pro model is pretty accurate. I've got one and did some test vs the track timers and it was within a couple tenths and ~3mph. The HP estimate is based off of weight. I don't know how you could have gotten that correct though.
