Fuse help
14bCrazy
Virginia
The 100 amp fuse that is in that black box on the pos. side of the battery is blown. The question is how do you get it out. There are four fuses on it and two pull on very easy the other two don't. Do those have to be onbolted fron the box or something?
toybreaker
iconoclast
The plastic case opens up, and there's 2 6mm bolts (with 10mm heads) that pin the fuse in.
Be sure to check for the cause before replacing the fuse.
14bCrazy
Virginia
Oh I believe I know the cause. I put the battery on backwards. The Miata battery I bought has the terminals opposite of the battery that I toke out. /ubbthreads/images/graemlins/banghead.gif That would cause it I would think.
toybreaker
iconoclast
Be sure to check the alternator fuse in the front box as well.
14bCrazy
Virginia
It's all good. I got the fuse and it's working fine now.
