BluFalcon
Got some 1G and 2G DSM stuff for sale. Figure some of this can be used on GVR-4's as well. Cleaning out the garage and could use the cash. Prefer pickup if local, otherwise buyer pays shipping and any PayPal fees. Feel free to message me with any questions, offers or snide remarks. Located in the Wichita, KS area.
1. 60mm Greddy White Faced Boost Gauge- Peak Hold with Warning Light. Complete setup, pulled from a running car. Includes Control Box, Gauge, Sending Unit, Power Harness, Sender Harness, Gauge Harness and Adjustment Tool. -$125
2. Road Race Engineering 1G AWD Downpipe- RRE doesn’t make these anymore, as far as I know. I believe this is one designed to run a EVO3 O2 Housing. If so, the upper flange of the downpipe is clocked to accommodate the angle that the EVO3 O2 housing uses. The first bend before the flex section is 2.5in in diameter then expands to 3.0in after the flex section. This DP is in really good shape. I'll try and confirm if it's one for a EVO3 O2 housing.-$150 <b>*Edit: According to the PO, this is a EVO3 DP for a 1G AWD*</b>
3. 90 AWD ECU (Non EPROM)- Used ECU pulled from a parts car, that sat for a few years. Looks to have had the capacitors replaced in 2003 by Auto ECM in Grand Prairie, TX. -$60
4. <b>*SOLD*</b>Mishimoto Aluminum Fan Shroud with 2 10in Slimline Fans For 1G DSM- Practically brand new shroud and fan setup. I installed it temporarily on my radiator for a mock up, but then pulled it off in favor of a larger fan for the passenger side primary fan. Bolts up to a stock or aftermarket radiator utilizing OEM style mounting points. Bought new for $180, asking -$140 <b>*SOLD*</b>
5. 1G AWD 6 Bolt Fidanza Flywheel- Used stupid light Fidanza Flywheel for 1G AWD DSM with a 6 Bolt. Includes brand new friction surface kit to replace the friction surface currently installed. -$125
6. <b>*SOLD*</b> 1G DSM “Custom” Griffin Aluminum Radiator-
This is one of 3 radiators custom made for a group that road raced a pair of 1G AWD's back in Dallas. It was installed on my 93 Talon when I got it. As you can see it's quite a bit thicker than your normal drop in radiator (3.0in), so if you're running a big turbo you might have to get creative with your fan and intercooler piping setup. But you definitely will never overheat with this thing installed. It's completely drop in with a bung for the coolant switch and threaded inserts for the factory or aftermarket fans in the factory location.- $150 <b>*SOLD*</b>
7. 14B Turbo- Used unit pulled from a 91 Talon TSi parts car. Has minimal radial and axial play. Some slight erosion on the leading edge of the compressor wheel, but no indications of rubbing on the compressor cover. Turbine housing is a unported 6cm with some cracks near the wastegate area, but nowhere as bad as I’ve seen on some other 14B’s. -$50
8. <b>*SOLD*</b>450cc Injectors- Spare set, I have lying around. Tell your Miata or Honda buddies. -$40 <b>*SOLD*</b>
9. 1Ga Talon Rear Taillight Panel- Panel that fits in between the taillights. No cracks, and could use a little polishing. -$25
10. <b>*SOLD*</b>1G DSM 3 Gauge A-Pillar Pod- Pod is warped all to hell and back and the gauges are sunfaded. Includes three Autometer Phantom gauges in 52mm. Narrowband O2 Sensor, Mechanical Oil Pressure, and a Boost Gauge. What you see is what you get. If someone were so inclined, I’m sure the pod could be straightened out with a little heat. -$30 <b>*SOLD*</b>
11. <b>*SOLD*</b> 2G Prothane Motor Mount Inserts- 2 Prothane motor mount inserts for a 2G. Was going to use these in my old Spyder, but never got around to it. 13-502 (FRT) and 13-504 (RR). -$15 for both. <b>*SOLD*</b>
