FS: Old School FP Red
raptorWagon
Oak Harbor, WA
60-1 Compressor wheel, 7cm turbine housing, setup for external wastegate on manifold (flapper welded shut)
rebuilt by FP about 5-6yrs ago, hasn't been run since. $500 + shipping + paypal fees.
alansupra94
Wayne,NJ
Quoting raptorWagon:
35R Compressor wheel, 7cm turbine housing, setup for external wastegate on manifold (flapper welded shut)
You have any specifications regarding the turbo? I can't seem to find anything.
raptorWagon
Oak Harbor, WA
Yeah they have changed this model so many times over the years. From what I remember
Flow is 65lb/min
35R Compressor
20G turbine wheel
7cm Turbine Housing
JNR
ca
Don't know if this helps with any info, but here's a snapshot from 2004:
GalantTuner10
Waterbury, CT
Specs:
60-1 compressor wheel
Clipped TD06H turbine in a 7cm hotside.
Flows a good amount of air and decent spool
IncorpoRatedX
Arizona
Just checked this out today, I've had my fingers inside of and maybe other body parts. It's very nice and tight. No play.
I'm tempted to buy it but I have nothing to put it on.
raptorWagon
Oak Harbor, WA
Quoting GalantTuner10:
Specs:
Had a 60-1 comp wheel at one point, when it was rebuilt it received the 35R wheel. /ubbthreads/images/graemlins/smile.gif
GalantTuner10
Waterbury, CT
^^^ this.
raptorWagon
Oak Harbor, WA
Thanks for the correct info Donnie, I was told it received a 35r wheel. Still doesn't change the price any.
