broxma
Every part for the Manual conversion. Both A pillars, Upper and lower B pillars and the upper trim piece. Both retractors, all hardware, all the spacers.
To let everyone interested know, under no circumstances does this "bolt in". That notion is a lie. You will have to drill into the A pillar to allow for the clips to go in because those holes are not there. Some things also may have to be slightly modified to get it all to fit. I will send the lower covers for the retractors which I modified already.
These parts are fragile like glass. Shipping will be in a large box to allow for as much padding as possible. The Driver A pillar piece did crack and was repaired already. The repair has worked beautifully since I installed it however since there is not a lot of stress on it.
Pictures.
I need 225.00 + actual shipping
/brox
Pictures.
/brox
