FS: gvr4 fmic kit
biglady112
Commerce City, Co
We are selling this kit as we are moving to a hotpipe setup on 338/2000. This kit has been on the car for nearly 40,000 miles. So it is not new. It does hold boost well and there were no boost leaks the last time we did a test. This was originally setup for 14b and 16g turbos. Unless someone needs it I will not send the piece that bolts onto the 16g compressor housing as it is not a good piece to use. Just not ideal. It will come with all the clamps and couplers you should need. This is a Garrett core in the intercooler. It measures 24"x12"x3.5". The endtanks are 31" wide. You do have to cut your metal crash bar to run this like most galant kits out there. It will also come with a GM MAF AND translator. We are moving to speed density so we do not need it. We also are going to be reusing the stock BOV on our new setup so it will not be coming with it. Unless someone really needs it and wants to pay a few extra bucks for it. This kit was setup for use with a 1G non-turbo throttle body.
$325 shipped with PayPal fees
Steven
720-483-9375
