FS: 91 Galant Vr4 #1075/2000 Lowell Ma $4,500 SOLD
Number4
Lowell MA
1991 Galant vr4 Belize Green # 1075/2000 runs very good and strong compression at 165 all across
Exterior I say its about a 7 out of 10 just because it has a few little dings interior I say 9 out of 10 and that's because the drivers seat is unsewed and drivers door speaker cover is not there but other than that is nothing major... $4,500 or B/O
Mods..
Rebuild Block
Arp studs
272cams
evo3 16g/2g manifold
850 fic injectors
2 1/2 buschurracing downpipe and catback..
255 walbro fuel pump
Dsmlink on 2g maf
Greddy Bov
Fuel pressure reg..
Act 2100 clutch/aluminum flywheel
Tranny said to be a shep but I really dont know how to determine that because I got the car with it on plus it shifts great and never had a problem with it...
4 bolt rear end
5 lug converted
ngk wires
big fmic with hard pipes
93 headlights/and stock
whiteface cluster /and stock
Grant steering wheel
Gr2 struts at front agxs on rear
I have talon wheels on winter tires and 93 rx7 wheels with street tires which are on the car right now...I'm pretty sure I'm forgetting a few things...Here is a ramdom pic I took like a week ago....Pm for more...I could go out side and throw some....Thanks..
RACER-X
Corpus Christi, Tx.
interor pic, and is there any rust or leaks?
Number4
Lowell MA
This car ran 13.8x when Brent owned it with a 14b the car is running very healthy with the evoIII and the boost leaks fixed...I say it should easily be a mid to high 12second car....
Might I add this car is #81 on dsmtimes.org Gvr4 list. Bump for Harold he is a great guy to deal with.
RACER-X
Corpus Christi, Tx.
on an 18 yr old car you have to be more specific.
Number4
Lowell MA
170something k on the shell and about 20 to 30k on the rebuild...Any one is welcome to come with a compression tester....165 all across.... very healthy car...
I hope he doesn't mind me posting up but the Head, bottom end and tranny all have under 20k. I got the car when they had about 5k on them and over my three years owning it I put under 15k on the car!
Number4
Lowell MA
Thanks Brent thats info I didn't know Myself...I got this car from him and he could answer alot of the motor question....
