FS 4g63 $600
bassman1
Richmond, VA
Local pickup only. I really need this gone, so I am asking next to nothing for a recently built engine. $600.
-Built 6 bolt 4g63
-New Rear Main Seal
-Manley Rods (H Beam)
-ARP Rod Bolts
-Wiseco Pistons
-ARP Head Studs
-ACL Race "Tri-Metal" Main Bearing Set (.25mm oversize)
-Cometic 1.3mm Head Gaskit
-8.1:1 Compression Ratio
*****Will need Oil pan/Valve Cover gasket and a crank pulley
bassman1
Richmond, VA
Intercooler/piping sold a few minutes ago, I will have to check to make sure the driver side kick panel is in good shape if it is does $15+shipping sound reasonable?
bassman1
Richmond, VA
I will check on the hood Tuesday when UPS is open... The FPR is gone but the intake and exhaust manifold are still available. PM me your zip+which one you would like. Sorry it is taking me a bit to get back to everyone, lots of requests.
snohacking
Menomonee Falls, Wi
Quoting bassman1:
Can you do $17 shipped I know it a small part and will fit in a flat rate box.
how much do you want for that lil VR4 badge?
LIV4PSI
O-H-I-O
Quoting GSX_TC:
JNZ sells them new for $30
Free bump for the OP!
