jnava
This engine is a 6 bolt but the head has 2g revisions. Both a 1g and 2g capable engine. $2K.
Ross pistons
Eagle rods
Oem G4CS 100mm crank
BSE
Fidanza cam gears
FP4r cams
ARP head studs
Timing component
Evo Beehives
3g lifters
Ti retainers
Ed's original ad:6 Bolt 4G63 Block- Machined Internally For Rotating Assembly Clearance
New OEM G4CS 100mm Crank
New Eagle Rods
New 2.3L Specific Ross Pistons
New OEM Mitsubishi Front Case and Straight Cut Oil Pump Gears
New OEM Bearings, Seals and Gaskets Used During Assembly
ARP Head Studs
Ross pistons
Eagle rods
BSE
Fidanza cam gears
FP4r cams
ARP head studs
Timing component
Evo Beehives
3g lifters
Ti retainers
New Eagle Rods
ARP Head Studs
