FS: 1992 ????/1000 littleton colorado $2000 SOLD!!!!!!!!!!
bob92vr4
littleton colorado
this car has a lot of good parts shep stage on bellhousing has a crack that has been professionally repaired, dsm link v3 running speed density, prologger widebind and electronic boost controller 4 bolt lsd, hand built t4 divided flange manifold by steve at pfi, cant remember the specs on the turbo but has a 3 inch vband outlet, hard pipe fmic, civic half radiator with big spal fan, konig 17 inch tantrums, new tires, front axle's, new breaks all around new tbelt with b shafts removed and ble manual tensioner, the car has 191xxx miles on the chassis clean body for a 1992 one dent in the valence between bumper and drivers corner light and the usual door dings, interior is pretty clean too no rips.
The bad i installed /ubbthreads/images/graemlins/banghead.gifthe turbo and fed it from the head burned the center section up so it is dumping oil in to the down pipe and i mean dumping so the car will be sold as a tow away only! it needs the exhaust finished its there just not finished. the wiring needs cleaned up. the ac is gone all of it. 4ws has been unhooked but the lines remain in the car, needs stereo, im not sure what struts and springs are in it but they are not stock, need a new fuel line from filter to manifold not sure why but the po tapped into it and teed off for something it is plugged right now.
Puertorican22
Active member
Aurora, Co
What is the least you would take? I might consider buying it for some of the parts for my VR-4 and to part out. I'm in Aurora.
