FS: 1991 VR4, PA. $4700
15psi88
State College, PA
Located in Yeagertown PA 17099
110,539
Engine
- bored .020*
- 2g pistons*
- King main & rod bearings*
- BSE*
- 3 angle valve job and resurface*
- New OEM valves/springs/retainers*
- BC 272's*
- 90 oil filer housing*
- stock 90 cooler with -6an lines*
- Prothane mounts
- 1g rad
- 2 10" pushers wired to stock harness*
- ACT 2600
- ACT Street lite flywheel*
- Generic fmic* (blacked out)
- Custom piping by myself*
- SBR cast manifold
- Tdo5h 20g*
- 2g Mas/ K&N
- TB half shaft mod (and rebuilt)*
- DejonTool dumped 02 elminator
- BR 3" stainless catback(catless)
- TT supra pump (very quiet)
- PTE 680's*
- Aeromotive FPR*
- AGX/ prokit(front)about 2400 miles ago.
- GR2/ stock (rear) Needs VR4 rear prokit
- 16" 5 spoke 2g's
- BFG Gforce sport 225/50*
- Keydiver Chip*
- Safc2*
- Boost,oil pressure, water temp
- Battery in trunk
- No AC, PS, AWS
- Turbo timer in center console
- 20% tint
- Crusty steering wheel mod
- Pads/Drilled slotted rotors*
*= All done 1800 miles ago.
Barely broken in, BUT:
Needs a head gasket.
Also sunroof brain is dead, Tcase output shaft seal seeps, left front wheel bearing squeaks.
Things to sweeten the deal:
New act 2600
New 1g Fluidyne Radiator
stock o2 housing with 3" Buschur DP(in case external dump isn't your thing.)
stock injectors
$4700
I will only trade for a 88-93 Mustang coupe in similar condition. 5.0 preferred, 4cyl, we can talk. No red interiors, No exceptions.
Prior to 5 lug
VR4ownzU
Orlando, FL
I love the way those white 2G wheels look. Remind me of RC wheels. Goodluck with the sale!
1941Galant
Charles Town, WV
Sweet car, it looks a lot better from when I parked next to you at Beaver Springs.
*edit - I'm not saying it looked like crap then, I just like what you did with it.
RACER-X
Corpus Christi, Tx.
Is it daily driven? How bad are the leaks? If the head and bottom end have been freshened up why does it need a head gasket?
VR4ownzU
Orlando, FL
If you fix the issues it has I will pick it up. I just don't have time with fall here and two jobs to be working on anything.
15psi88
State College, PA
The car was daily driven.
The transfer case only leaks about 3 drops overnight.
The second fan has never actually been wired in. I would just hotwire it when I would go out. A few days ago in traffic it got hot.(I didn't have the second fan on) Now it's pressurizing the cooling system.
If I fix it, I can assure you I'm keeping it.
Sell the spare parts I'm giving up. Put a headgasket in it. Have a great, fast car, in awesome shape, for less than 5k.
VR4ownzU
Orlando, FL
Is the 2600 thats in there good? Same price for the car without the extra parts?
15psi88
State College, PA
The clutch that is in the car is great yes. The spare 2600 came from my Talon. I had it installed but the project is going a different route now and a twin disk will be used. It's still new.
If I keep the little extras I guess I'll do $4500.
