FS: 1991 Green (515?) Runs and drives...need to be finished $3500
91 vr4 forsale
Selling my galant. Some one buy it.
Green. interior is in good shape, body is fair, runs and drives. Needs to be finished.
Motor: Stock shortblock, balance shafts eliminated, hks belt, new pulleys/tensioner,fresh head (super tech dual springs) evo lifters, hks 272s, ported and polished stock IM, ARP studs, and all that jazz.
Trans is a clean shifting 92, new oem shift cables, ACT 2600 with a factory flywheel, new seals and TOB
ABS and PowerSteering deleted. 4 Bolt rear, new rear wheel bearings, "big" front brakes, newer ebrake cables, has evo front struts on tein springs and 1g agx's in the rear....i have both complete sets of suspention to go with it.
Random stuff, FPR. evo 565's, 255lph with maybe 5 hours on it, koyo full size radiator, EPROM ecu, Greddy shifter knob, dual din tv, 16g with flap welded shut.
The car has a full turbo back exhaust 3" downpipe with a slip fit and the rest back to the bumper is all mandrel pipes i cut and tig welded. No one still makes a nice exhaust for this car
looking to get 3500.
needs IC pipes made, battery relocated and DSM link and some small sh*t. fan wired in properly, idle speed motor, rear caliper sticks open some times and makes a rattle. i have a ton of parts to go with it. if someone jumps on it quick ill include some parts i have laying around (evo front calipers, wide band and random gauges) sh*t like that. trying to pick up a new daily by the weekend...my jeep is for sale to. 2004 grand cherokee special edition (leather v8 and all the options) very good shape. silver
im located in Milford Ct, cell number is 203-913-3683..usually txting is the best way to contact me or email if that your thing [email protected].
new parts i forgot to mention in the first post
alternator, water pump, all gaskets, battery, oem radiator hoses, comes with a Forced Performance 4" cast aluminum intake pipe with K&N filter for speed density, THE WHEELS DO NOT COME ON THE CAR... i have a set of 17" 7 or 8 spoke wheels with nearly new all season tires. They are white but you can paint them and they will looks decent.
The car does not have rot, it has some small dents on the roof in front of the sunroof, i was told its not much work to push them out but it didnt bother me. Some one repaired the lip of the quater panel, if you find a rear bumper and sand off what the attempted to do i think it will look much better.
calcaliente
Active member
Oakland
sold
