Quoting belize1334:
You said you can feel it in the floor boads? Maybe you have structural damage to the chassis or the front subframe.
Naw, I had the car checked out by a body guy I know when after I purchased it and to pull out the core support on a frame machine. Unibody is nice and straight on a laser rack.
The car has zero rust underneath. No structural damage that I can see either. Considering where the front subframe mounts, any banging going on in the front end would probably transfer the feeling right into the underbody/floorboard.
I wonder if the bushings for the front subframe are worn? I'm not really sure how that could happen though, and everything looks okay. I also checked all the mounting bolts and they were tight.
