FMIC and keeping the foglights...
Tre3zy
South San Francisco, CA
hey guys looking for a front mount intercooler design that keep my fogligts.... i know that the ETS KEEP will do it and also jonvr4s kit but is there other way to do it using a universal piping kit? and wat size end to end intercooler should i use?
fivestardsm
Middle, Michigan
Design your own, You will appreciate it more.
You can always just buy a core and have whatever endtanks you want welded on. Or have the endtanks modified.
atc250r
Orange County, NY
Go with a short route DSM one. No worries about the fogs.
fivestardsm
Middle, Michigan
^^ I know that guys have done them before, but how much of the core suport needs to be hacked? I was going to do it on mine, but didnt want to hack the hell out of the core, or change to a smaller radiator.
If you do it like Brian and I, hardly any sheetmetal needs to come out of the core support. Right up behind the headlight on the passenger side. Look at my sig link to see the pics of my core without the bumper and headlights mounted.
Tre3zy
that design you did is clean 5stardsm.... hey wop where did you get your intercooler core??? cuz i originally wanted one like yours cuz its a short route.... but i cant find any that is not gonna put a hole in my pocket lol
It's a Spearco 2-216. I bought it off a guy on this forum that had a couple of them years ago. It was just a core and the sheetmetal to build the endtanks. Andre welded it all up, but the core alone was $400. They're not cheap.
Tre3zy
cool thnx wop.... yea they are not cheap but at the same time reasonable price.... i think ima try to find one that has a similar design and then work my way from there.... although you have a jdm bumper... you think its gonna fit the same in my usdm bumper?
Tre3zy
cool thnx for the info wop....
slugsgomoo
Tacoma, WA
fivestar: here's a pic of my car where you can see how the car is trimmed for short route piping pic
it's not as if you're cutting into the rails or whatnot, just trimming out some of the thin stamped metal. Hasn't negatively affected my car /ubbthreads/images/graemlins/dunno.gif
atc250r
Orange County, NY
I have my AC out so the only thing I can add is that I'm pretty sure TurboTommy had a 2-216 core with short route tanks on his GVR4 and I know for a fact he had working AC on it.
John
slugsgomoo
Tacoma, WA
Quoting turbowop:
But slugs, didn't you remove your AC condenser?
yes, but it fit with the short route piping. Thinking back on it, I think the issue I ran into was that the radiator was in the way on the passenger side by ~1/2" so I ended up moving the brackets towards the drivers side maybe an inch? Shifted the radiator over and then everything fit fine. I'd test fit it again, but I don't think i kept the condenser so I don't know. I'm doing a similar setup with the sirocco radiator now though.
Yeah, I just looked at my car. The condenser leaves enough room, but you won't fit 2.5" pipes by the radiator without moving it over.
