yubh8tn
I have two broken GVR4 trans. One broke a while ago shifting hard into 3rd gear. Got stuck in 3rd gear. Newer trans broke after spinning all four wheels on an ice patch in 1st gear. I drove it to a parking spot after spinning it and a couple hours later when I tried to drive away it wouldn't leave first. I can physically move the shifter around but even neutral doesn't exist. Shifter cables arent broken and are still connected so I'm assuming both of those breaks were shift forks, hopefully not the same one. I have absolutely no money but I have lots of time and I am very determined to get my car working for more than a week at a time. Both transmissions lasted me a week of driving (not a week of time, a week's worth of driving). I'm tired of my shitty car not working after putting hundreds of hours and 15,000 dollars into it. The second, newer, transmission is supposedly a low mileage rebuild. So that whole speech was just to ask this: should I replace the broken parts in the newer trans with the parts from the older trans? And if I do, how realistic is doing that? Is that something I could figure out with a lot of free time but no money? And if I do combine them into one transmission, how do I not break it again? I know driving easy on it will make it last but I don't know how to do that. What is driving easy vs driving hard? Then what else should I look out for? I heard things like clutch alignment and shifter cables/bushings can cause a lot of durability problems if not done correctly. What should I do? Help
