evo3 ecu
tintoy
philippines
I have a stock ecu(5808), im planning to use an evo3 ecu. Do i need to rewire? And also would it benefit me using an evo3 ecu? /ubbthreads/images/graemlins/confused.gif
Evo3 has much more compression 9:1 so maps are different. They are closer to a 2G then a 1G. Evo III is also different maps then Evo I-II (8:5:1)
I believe you will need to rewire since Evo 1-3 is specific to that run of cars. I have the wiring diagrams of EvoIII ECU pinout if you do need them
RedTwo
New Zealand
IIRC You'll have to find the AFM (with an 808 stamp iirc) from an Evo or 2nd Gen VR4 and 510cc injectors for it to work happily in stock form.
I've only heard of one person figuring out how to rewrite the EPROM chips in these ECUs.
fuel
Toronto, ON, Canada
609 is the AFM you want, also found on some Diamantes
tintoy
philippines
Already have a 609 maf, 510cc, evo3 fpr, evo5 fuel pump and big 16g. Do i have to replace my stock ecu?
Eprom chips are pretty easy to get. I just sold one for 660cc's I had made. I will half to lookup the site. If that's what you mean
Also Dsm link works well for it later down the road if you went that route
Matching the ECU with the correct electronics/sensors are key to any proper operating efi engine. Especially in stock form. Tuning it is the next step
It can't be that hard to rewire really? What are the plugs on a GR4 like? 1G or 2G? CAS? or crank/timing cam?? Probably no one does it because of the at hand standalones available I would bet.
