evo x owner to white galant vr4
My name is jonathan. I gave up my phantom black evo x yesterday because it was just a money pit on top of a 500 dollar car payment. The same day I purchased a white galant vr4. I am picking it up tomorrow. The dealership owner is a dsm enthusiast and has built several fast dsm's. He told me the motor comes from a gsx and it has less than 10k. In all honesty I am not used to building a motor. All my cars have been new and I just through on bolt ons and had the ecu tuned. I would really apprexiate advice to bring this car to 400 hp on 93. I'm guessing a fp stock frame, injectors, dsmlink and a clutch..what common problems do dsm's have. I always heard horror stories about dsm's. Thx guys in advance
cheekychimp
East Sussex, U.K.
Jonathon Hi,
You are something of a rarity on here, a lot of the guys end up giving up the VR4s and moving on to EVOs. Firstly be prepared for the board members to start chiming in and chastising you for calling the VR4 a DSM. All VR4s were built in Japan and imported whilst DSMs were USDM cars built in the USA. Now there are a few double standards going on here in my opinion because on the one hand guys regularly extoll the virtues of stuff built in the good ole US of A whilst going on to say the build quality of DSMs is crap and that the VR4s are put together much better. Not being an American and not really knowing that much about DSMs I can't really comment.
What I will say is that the 4G63 is a f***ing awesome engine, probably one of the best engines ever built and if looked after will give excellent reliability. The issue with DSMs (build quality doubts aside) seems on the whole to be the owners. And whilst I don't want to suggest you are anything like them, I would say that one of the things that really does lead to the horror stories regarding DSMs is when people buy a car and without doing the slightest bit of preventative maintenance or fixing existing issues, throw down a wad of cash on injectors, ECUs, turbos, exhausts, yada yada yada!
It's a 20 year old car. Expect it to have issues and if you find none expect the gremlins to start showing their ugly heads fairly soon. Unless you have very good assurances backed up with some proof of a recent timing belt change, do a timing belt job. Old timing belts, especially those that have perished, got brittle or are contaminated with oil tend to snap and when they do your valves and piston heads will become very closely acquainted following which your wallet or cheque book will become good friends with the local parts store.
Change all your belts, change your fluids, change your spark plugs (and at least check the wires) check the bearings and bushings, listen for grinding from the transmission especially 2nd gear. Check your ECU and smell it! If it smells like fish, your capacitors have leaked and your ECU needs attention. Be wary of a bad idle, your throttle body may require a rebuild and if the issue is traced to a bad Idle Speed Controller (ISC) be careful. If these short out they can take your ECU with them. Check your exhaust manifold for broken studs and check the entire intercooling system for boost leaks. Check the fuel pump and sock and the tank in general and swap out the fuel filter for a new one.
In other words make sure everything is working great stock before you even start pricing up bolt ons. Again this is just my opinion but one I know a lot of others will share with me.
If by some stroke of luck (so large that it would necessitate being referred to as a miracle /ubbthreads/images/graemlins/grin.gif) there is nothing wrong with your car then start looking to build things up in stages. There was a magazine years ago that did a run on building up a VR4 and they dynoed the car after each successive component was installed. I believe it was "Turbo and Import Cars" or "Turbo and Compact Cars" something like that, (I can't recall!) In any event, you will find in general that the stock USDM vehicle has one major built in restriction that you will want to remove in order to really make gains with bolt ons. The stock SMIC is an awful bottleneck. Ditch it for a JDM stock front mount kit or some aftermarket FMIC kit for at least 30hp straight off the bat. The stock 450cc injectors are a bit small compared to EVO stuff and for 400 hp you'll want to look at using something like EVO 560cc injectors or a little larger depending on whether you want to use meth injection with your 93. Most guys go with bigger cams but 400 hp 'might' possibly be within reach on stock cams. An exhaust will help especially as you will want a bigger turbo. 400 hp has been made on the EVO III 16G but most mortal people won't manage that on a 16G framed turbo to be honest so maybe look at something like an FP Green if you want to avoid a lot of fabrication that goes with running some more unorthodox setups.
You will need a clutch to hold 400 hp. Dozens of options on that one so I won't start there, do some searching on here there have been three or four threads on clutches recently. ECMLink is a great setup but again a lot of guys on here are having great success with EVO 8 ECUs, Ostrich Emulators and the good old Keydiver DSMChips so for your fairly modest goals you might be able to save some cash here.
It is worth noting finally that 400 hp is about the reliability threshold of the stock engine. That's why a lot of guys like the EVO III turbos. You can get 300-350 hp all day with them, good tuning has made more than that and you can rag on a car that has supporting mods all day and it will still be pretty reliable. So if you are looking for a reliable car that you can drive all day, I'd be tempted to lower your power threshold goal and go with something like that. I did a big build on one of my Galants and for the other daily driver VR4 I'm mostly stock and have just a small 16G in the works to go on later this year.
Anyway just some ideas for you here and I'm sure the supporting cast will throw in more opinions when the guys on your side of the world wake up!
Paul.
trunks
Annandale, MN
Pics plz.
Your on the right track - e16g, mbc, and a bigger fuel pump to go with those injectors. I'm not sure if the gvr4 intercooler is okay for 400 hp?
1. Car is not a dsm.
2. Take care of your maintaince and there is nothing to be scared of. Get a boost and wideband gauge if your going for higher horsepower.
3. Welcome to gvr.org.
Brunoboy
San Bruno,CA Home of SFO
Quoting trunks:
Pics plz.
stock intercooler is not okay...
my intercooler is not okay!!! wtf! jk
welcome to the forum
welcome to a new money pit.. possibly even deeper one. BUT mods are cheaper then evo mods
and everyone knows that white vr4s are faster then any other color so your off to a good start there
Brunoboy
white is definitely the fastest color lol.
coolclean577
Omaha NE
welcome man hope the best out of your vr4. its like you got to be rich to own galant, dsm bec there in the shop every week or just broke down but i'll never sell mine. good luck
mistaVR4
Boulder, CO
Welcome bro! Paul's post couldn't be more accurate if anyone tried /ubbthreads/images/graemlins/smile.gif Good luck with the car. Once it's where you want it, and as reliable as it can be you will love it and never want to sell it!
BTW: KG's are the faster then Summits /ubbthreads/images/graemlins/tongue.gif
Thanks paul for the amazing write up! So much info and thought involved! My car is number 1155. Car runs great surprisingly. Slow as a civic but runs well. 14b is omg weaksauce. Car has a new paintjob, and a cloth interior. James, the previous owner told me the leather was ripped. Suspension creaks and rattles like an old wooden cabin. Anyone have thoughts on a suspension route? I love the low even stance if that's possible (springs preferably). I want a thick tire and a small rim. Possibly 16" 5zigen fn...I heard 1g springs go right in. The normal bolt on path is coming soon. Ecmlink, bc, 3" turbo back from a 1g, injectors. Fp red may be my route..
Brunoboy
14b maxed out is pretty fun, 16g is really fun as a dd car. I run Evo Suspension as some others here do as well. theres a write up in the how to section if you'd like to check it out.
Welcome aboard. FP red is a little much just for your 400hp goal. Just make sure you have the supporting mods, like a fuel pump, injectors, front mount, ECMlink, clutch, arp head studs and I'd remove those balance shafts here's a link that you should read
well I made a decision to get my evo x back. So now I have two cars. I am thinking of swapping parts from my evo to the galant and giving the evo up again. What parts would u guys put in your galant if u had the chance?
donkeylips
Rochester, NY
What you say doesn't make any sense.
I see threads about evo viii and ix parts going in a vr4. Was wondering if anyone had experience putting evo x parts in the vr4.
Perkul8r
Mandan, ND
Well, with the EVO X having a completely different motor. I dont see how any parts could fit. The 8&9 were still a 4g63 variant, while as the 10's are a while different motor.
Quoting evox2vr4:
I would Def get the Brembo Brakes and Rotors off that car. maybe even the Front Mount aswell
donkeylips
Rochester, NY
What is this, you're parting out an Evo X?
Nah man he said he was getting his EVO x back and was asking if he could swap any parts off it to his vr4
donkeylips
Rochester, NY
I know, I'm just saying that it sounds very fishy to me. Is he getting the evo back just so he can take some trivial parts off of it to put on the galant, then getting rid of it incomplete? Or is he getting the car back, and upgrading parts on it, using the stock stuff on the galant? None of it makes sense, I think he's lying or /ubbthreads/images/graemlins/uhh.gif
He bought a $30k car and got rid of it so he could buy a $3-5k car. Now he's thinking about buying the $30k car back so he can put parts on the $3-5k car??? And then get rid of the $30k car again? And will it be complete anymore? Come on. I think I'm so annoyed because this reminds me of people I know who say things like this.
Maybe instead of "giving up" the car because it was a money pit, he totaled it and is thinking about buying it back /ubbthreads/images/graemlins/rofl.gif
donkeylips
Rochester, NY
This is probably his evo x. /ubbthreads/images/graemlins/rofl.gif
