bcjjones
I'm in the process of wiring up an evo 8 ecu. I'm currently on pin 3 of the evo 8 ecu which goes to the fuel pressure solenoid. Only problem is, there is no wire coming out of the evo 8 harness on pin 3. Just making sure I am in fact missing a wire and im not supposed to skip 3 and use the 4th wire as pin 3 going to the fuel pressure solenoid?
Also, if I am in fact missing a wire, how would I go about pulling one of the unused wires from the harness connector and moving it to pin 3?
Any help would be greatly appreciated!
Thanks!
Thanks!
