sublimesnfu
I picked up a complete rear sub frame off a 93 Talon for the 4bolt diff to put my EVO lsd in. I've read that I can use the TEL rear sub frame on the VR4 and was thinking about cleaning the sub frame up and swapping out the bushings and installing the complete sub frame at once with the diff and axles all at once.
So the questions are is installing the sub frame a dumb idea for some reason I can't figure out?
Also if I'm using the talon sub frame wouldn't I use a TEL rear sway bar instead of a VR4 rear sway bar? /ubbthreads/images/graemlins/dunno.gif
Thanks /ubbthreads/images/graemlins/smile.gif
