DynastyLCD
got the blue car goin again. today i got on it in 2nd, and it just shot sideways, it felt like all the power was going to the rear wheels. tried to take a tight corner to get it in the garage, front wheels skip and bind up. also, if the wheels are turned, it requires more effort to move forward.
is this the signs of a worn center differential, as it cant transfer the power front and rear anymore? or is it related to the front differential?
my other question is, if the center diff is damaged, will replacing it with a welded center diff and viscous coupling eliminator fix my issue?
its an older trans/tcase i had layin around, the clutch is a (properly adjusted) like new PTT, and all the axles are good, nothing popping out of the boot or physically binding.
