Cylinder Head Question
I have used one on my 92.
89Mirageman
Stantonsburg, NC
Plenty have, I'm doing it now on my 94 Summit. Well I'm actually using a 4G64 but same difference. There is some info in the archives over on 4g61t showing the difference in the head and also the Hyundai variant.
Terrance362
Winston-Salem, NC
Just didn't know how things how things would react to the smaller combustion chamber, I planned to run a whole lot of boost on this motor. The setup up is an 8:5:1 stock stroke, MLS head gasket, 288 cams, Kiggly race only valve springs.
fuel
Toronto, ON, Canada
4G37 is a completely different engine altogether - it is a 1755cc SOHC 8V with 5-bolt flywheel used in the 1G DSM along with other overseas market Mitsus like the base model 6th gen Galant, Chariot, Lancer etc.
I had some knock running basically stock boost with 91 fuel. I'm sure it could be tuned better but I never really bothered. It did seem to have a little better bottom end performance with the slightly increased from stock compression ratio.
Quoting Terrance362:
Just didn't know how things how things would react to the smaller combustion chamber.
