Critique my setup
NZ VR4 RS
new zealand
^it aint far away. /ubbthreads/images/graemlins/cool.gif
ronnycordova
Muncy, PA
I think the only real issue I had getting rid of mine is pressing in the one bearing that is back in the middle of the block....other than that it is easy peasy
mitsuturbo
Near Seattle, Washington
If you're referring to the balance shaft bearings, that's SIMPLE to get out. Just flip the front balance shaft around and stick it in the hole. Hit the end of it with a hammer and push the bearing out. Once it's out, position the oil hole in it 180° from the oil galley in the block, and put it back in the same way you pushed it out.
The only part needed for a proper BSEK is the stub shaft. Even that can be done for free, provided you have a welder, and a die grinder, or even a hack saw. Saw the back of the oil pump driven balance shaft off, and weld the hole shut. Or, if you don't have a welder, you can do what i once did. Cut the shaft, use a tap to thread the hole in the stub you've just created by cutting the balance shaft, and put a bolt in it.
