Connecting Rod question
GTX
Toronto, Canada
Hi engine gurus! I'm new to 4G63 engine and wonder when replacing pistons could rods be re-used if I'm using new pins? There is no pin locking ring on either side of the piston. I'm assuming they were press pushed in parts cold/warm state
Thanks
A
Yep, it's a press fit pin. Rods can be re-used as long as the are checked out. Need to be sure the large and small end are not out of round or have taper.
GTX
Toronto, Canada
Thanks Ryan! So, please correct me if I'm wrong here: All I need to do then is to press the pins out, inspect the rods, if ok, cool them down, cool the new pins also and press them in. Correct? Any special things I have to be aware of? All parts are stock.
A
Never done it myself, but I would imagine you don't wanna cool the rods when reinstalling. Just the pins. Are you replacing the piston with stock?
CutlassJim
Manchester, NH
You would chill the pin and heat the small end of the rod. Stock pistons are fine to reuse too unless you're changing to a higher compression ratio. The stock pistons are just as strong as anything aftermarket until you get into big money stuff.
EVO pistons make for great upgrades. Requires a larger pin and machining of the small end of the rod. You get a whole 1 point increase in compression.
2g pistons are good for 8.5:1 compression, EVO goes to 8.8:1.
GTX
Toronto, Canada
My cylinders are in a decent shape, but pistons have a bit of wear. Since the engine is out I will replace the questionable parts.
Only need about 300HP. Replacing pistons with stock. From what I read, Big16g should not destroy them if stay under prescribed pressure.
362Ryan
Alaska
I would still get a set of evo pistons. The bump in cr will wake the engine up on the street.
Also consider a 2g head. Running both of those would give you quicker spool up than a stock setup on a 14b.
mitsuturbo
Near Seattle, Washington
Depending on the machine shop, sometimes it's not worth it to have the stock rod reconditioned, then have the small end narrowed and the hole enlarged, due to cost. Considering you can buy eagle rods for 325ish brand new with whatever size pin end you like, I could see why someone would opt for stock pistons.
fuel
Toronto, ON, Canada
Yeah if the stock rods need any kind of work (ie boring out small end for 2G/Evo wrist pins, or reconditioning of any kind) then I would just drop the money on new aftermarket rods and go for higher CR pistons for better low rpm response. The previous owner of my car rebuilt the engine with stock (brand new from memory) 7.8:1 pistons and I wish he had gone for the Evo pistons instead.
When I built my engine I estimated the cost to recon the rods at about 200 with machine work, cleaning, and installing ARP rod bolts. I ended up buying some eagle rods for 280 shipped. An extra 80 for balanced, stronger, and lighter rods was well worth it.
