Clutch Master Cylinder!
ACT Australia
Hi guys, I just had the clutch master cylinder and it broke again two days after. Instead of getting the same one, is there any EVO clutch master cylinders I can use?? any help would be appreciated
AnotherNewb
Orlando, FL
What exactly broke? What kind of clutch are you using? Its not unusual for a box store clutch master to fail but rarely in two days. Your best bet for a replacement is an OEM placement, not a reman one from vato zone or ect...
ACT Australia
the guy said that there is pressure building up in the cylinder. and is like its rejecting oil from the slave slave cylinder. Its as if the clutch is continuously disengaged. I don't know whatt clutch is in it sorry.
EHmotorsports
Beaverton
did you adjust your clutch rod correctly? there is a certain procedure you need to go by.
click adjust
AnotherNewb
Orlando, FL
Ehmotorsports nailed it. /ubbthreads/images/graemlins/applause.gif Improper adjustment.
AnotherNewb
Orlando, FL
Yep. Plus not being properly bled because it wasn't properly adjusted.
