Cluster Lights, Power Transistor with COP
Boostin21
Wisconsin, USA
Ok so I have been working out some of the bugs with the car as i crank it over. Cluster lights worked and then didnt then they did now they dont.
Also do i need a power transistor when running a COP setup?
And yes the car is almost road ready! Just in time for storage! yay /ubbthreads/images/graemlins/banghead.gif
curtis
Clarksville TN
Yes you need a power transistor, everything stays the same except the plug from the factory coils gets plugged into the new unit. The 12volt power wire gets split and the two triggers run to there dedicated pairs as usual.
