MellowVR4
Hey everyone, ill try to explain the best I can. So about two weeks ago my alternator took a s#!t, replaced it, wrapped my wastegate with some heat wrap because maybe that was the cause of the alternator going bad? been driving it for a few days and had to take off the wrap to fix something on the WG. Anyway last night i drove the car, drove fine everthing was good, Then out of knowhere it felt like the volts went from 12v to a low 8v not accurate but thats the best way i can explain, Radio started to flash, wideband gauge went to E9 which is a low voltage signal to the gauge, started to misfire,run lean, I barely made it home. It started back up and seemed fine but then i turn the headlights on and the RPM'S where going down fast. I Think my alternator went out again but not sure, Im not gonna do anything till the weekend to see what i can find, If anybody has got any idea what might of gone wrong please chime in. Thanks to all in advanced
