carrier bearings?
pwvr41390
New member
toms river nj
Are the mounts that hold the driveshaft to the body called carrier bearings? I can't find replacement parts for this. Is there another name for them?
thomcasey
Indianapolis, IN
The "carrier bearings" are the rubber isolated bearings that the driveshaft rides in. They do have points on them that mount them to the body of the car. Those mounts have bushings that the carrier bearing reside in.
strokin4dr
Savannah, GA
Sounds like you are looking for the bushings/washers that hold the carrier bearings in place.
PC_Talon
Member
Lansdale, PA
This is the actual carrier bearing:
JNZ Tuning Carrier Bearing
