Can you ID this turbo?
citymunky
Chesapeake, VA
So this is the turbo pulled from 733/2000 and I'm trying to figure out what it is. I believe this is Turbonetices but I'm unsure
When I pulled the compressor housing it said "66-1 T04E." The turbo has a T3 inlet flange.
The compressor wheel measures in about Inducer diameter = 66.5mm
Exducer diameter = 83.8mm
The Turbine wheel measures in about Exducer diameter = 56.25mm
Inducer diameter = 64.00mm
EDIT: Well it looks like a "T" series turbine P/N:451314-0003 (77 trim)
http://www.turbomaster.info/eng/applications/turbine.php
turbohf
Lake Stevens, WA
thats a quality link you have there. ill need to make sure to save it for later. thanks
I think it's name is Martin.
