Software Upgraded - Reset Your Password to Login
Well the issues just keep coming now I found a stripped stud on exaust manifold. Above turbo I wonder if that why I'm not spooling up very well until like 4500. Well time for a helicoil this sucks real bad
^^^+1. I could not figure out why my turbo wasn't hitting full boost until 6krpm. I did a little searching in the manifold and noticed a slight crack on one of the welds. After taking it off, I found 6 cracks on the welds. 1 of the welds didn't even go all the way.
Well I have enlisted the help of boostedinaz. To help me get my car back to decent driveability.
I hate exaust leaks but if its just a crapy head bolt that would be great. Hopfuly not leaks elswhere . I will keep you all updated as this car comes back to life one $$$$ at a time
Quoting drdamm21:
If there's room, i just drill the hole out and put a nut/bolt thru the whole thing. Easily replaceable!
While it's out, check for trueness (flat) on both flanges; otherwise you'll never seal it all the way. Doesn't hurt and only takes a minute. I like to lap my flanges anyway, cause there's always some degree of tolerance and esp. on older oem with many heating/cooling cycles.
Quoting steveGLS:
Quoting SmoothCustomer:
Quoting Speed_Racer:
This is a leek:
Well I wouldn't want that in my exhaust.
Don't knock it 'til you've tried it.
I've made exhaust manifold burritos [img]/ubbthreads/images/graemlins/smirk.gif Great for wheelin. Exhaust manifold leeks? Doubt its as good. I'm sure tabasco would help /ubbthreads/images/graemlins/wink.gif
