bushings
Yao
Denver, CO
Hello all, I think it is almost time to replace all the suspension bushings for a 20 year old car. Does anybody have a list of ALL busing upgrades and where to purchase them? I am thinking 4 wheel bearings, tie rods, swaybar links, ball joints, pretty much a major overhaul and what needs to be done while I have it all apart kind of list /ubbthreads/images/graemlins/smile.gif
LIV4PSI
O-H-I-O
I basically just did the same on my car. I spent around $700 in parts when I was done. Here is what I bought
BoostX rear subframe and mustache bushings.
Energy suspension full 1g kit
From Rock Auto:
Front wheel bearing and seals
Rear inner and out wheel bearings with seals
Inner and outer tie rod ends
Front control arms (or just ball joints)
rear ball joints (same as front)
front and rear stabilizer links
OEM steering rack bushings and shifter bushings
The only parts I still need to do sometime are the rear strut bushings, and the bushings on the front U shaped brace that don't come with the ES kit.
GVR47111K
80022, CO
I'm pretty sure my car needs the exact same stuff as you guys. It squeaks going over almost any bump.
Quoting LIV4PSI:
Did you get any increased noise or vibration after these? I went with the softer bushings from him and I got a lot of noise upon acceleration.
LIV4PSI
O-H-I-O
I haven't installed them yet, but there is always an increase in NVH when upgrading to stiffer bushings. It bothers some, it won't bother me.
LIV4PSI
O-H-I-O
I wanted to add that I got my Energy Suspension kit and all of my OEM parts from JNZ Tuning. Good prices and even better service.
