Brett Adams' 1992 Galant VR-4 820/1000
Owner: Brett Adams
Message Board Name: GSTwithPSI
Year: 1992
Number: 820/1000
Best 1/4 mile time: N/A
Dyno: N/A
Build thread: 820/1000
Fuel:
• Walbro 255 fuel pump
• Aeromotive A1000 AFPR
• -6 AN feed line to rail
• New OEM fuel filter
• FIC 1150cc injectors (flowed tested at ~1200cc)
Intake & Intercooler:
• K&N 4.0" high flow air filter (RU-4260)
• 399 Evo 8 MAF
• Crushed OEM BOV
• Bar and plate FMIC 25"x 8" x 3" core
• 2.25" short route intercooler piping
• Cyclone dual runner intake manifold
Turbo & Exhaust :
• Forced Performance 68HTA (V2) turbo:
--- TD05H compressor cover
--- Compressor (51.2MM Inducer / 68MM Exducer)
--- Turbine (60.8MM Inducer / 54MM Exducer)
--- Internally gated 8cm^2 turbine housing
--- Modified Holset waste gate actuator
• 2G OEM exhaust manifold
• 2.5" turbo back exhaust
• Buschur Racing stainless steel heat shield
Cooling:
• New OEM radiator
• Stant 13lb radiator cap
• OEM 180* T-stat
• 12" SPAL high performance puller fan (VA01-AP70/LL-36A)
• Factory pusher A/C fan
Interior:
• MOMO "Racing Line" steering wheel
• MOMO SK50 shift knob
• OEM metal brake and clutch pedal covers
• JDM headrests
• Pioneer DEH-X6800BT deck
• Pioneer speakers (G series 4" & 5.25", A series 6.5")
• Kicker CompS subwoofer (40CWS104 single-voice-coil)
• Alpine-3527V amplifier
• Lamco OEM gauges (volt, boost, water temp)
Exterior:
• Thule roof rack
• OEM rear mud flaps
• 92' grille
• Amber turn signals
Motor:
• 6 bolt stock block
• Stock uncut crankshaft
• ARP head bolts
• 1G cylinder head (Oil port mod, BC1100 valve springs, 3G revised lifters)
• Stock cams
• Fel-Pro composite head gasket 9627PT
• All new engine gaskets (FelPro)
• New water pump and timing components (Gates)
• Gates accessory belts
• Gates timing belt
• Dark Art Carbon spark plug cover
• NGK BR7ES plugs @ .028
• New oil pump with straight cut gears & OEM BSE kit
• Prothane front motor mount/roll stop
EMS, Logging & Electronics:
• ECMlink V3
• Innovate LC-1 wideband
• NGK plug wires
• ECMlink boost control setup
Drivetrain:
• 5 lug hub swap
• Stainless braided clutch line
• Rebuilt TRE transmission (Red Line MT-90)
• B2B 3 bolt non-LSD rear (Red Line Heavy ShockProof)
• 23 spline transfer case (Red Line Heavy ShockProof)
• ACT full face sprung (4 spring) clutch disk & 2600 pressure plate
• Stock flywheel
• NSK TOB
Brakes, Wheels & Suspension:
• JIC Magic FLT-A2 coilovers
• Adjustable front camber plates
• Adjustable rear camber arms
• Muteki Sr48 lug nuts
• Enkei RPF1 wheels * 17x9 * 5x114.3 * Offest 35
• Federal 595 RS-RR tires 255/40 R17
• ABS delete w/ 1G AWD prop valve
• 4WS delete with welded trailing arms
• 1G DSM power steering rack
• Baer Track Claw big front brake kit (BAE 4611001)
• Crossdrilled/slotted 13" front rotors
• Braided stainless front brake lines
Parts Wishlist:
R-12 recharge <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
Speed density
Mods I'm waiting to install:
E85 swap
Here's 820 shortly after I picked it up (Aprl, 2015)
Here's 820 after the first round of improvments (August, 2015)
820 after a major overhaul (July, 2016)
October 2018:
EVAtVJXVsDgv-Wj1Lhgu13D1kIl64Ssba2CDdKQRnHabwxeEs7VVld8Tse6igxuaXYhsTy-xoQCrQXHlnfHj45YqimgtaZ_Vegzzif0dvEieYBKURJH7s2ocaD7PzmYT1jL_UjN98DnCQ6zVseAud-uI9zuHWgupOVMGVA5AmBiRSSyz-rpfJnT8eHc3QGEe7aFVgQ6D4393iOpNUnjXOZiBgl4vZIuT76nSsQf_HvntsmgrlfhNphs6qd4hb3fHdQmspSvpk95b6GYnmA4iNbH5N4CwtgSv9-kTFdgLlpbCsdFAJTaHhuqgVkFB-p1kCRTh2is8uNsM0RYX1wSeSz4qMVeX_p9Eysx8gUUAzByV8kzWywLY0vUTYC_fyd6yN8oQBp1yS20GEx3CM9zKPJPXcdzS42gKK5uGTcyAa5tbR9Hk2M9S5TfBdFnNvYsN1wv7-noY0FYAUQk1rvcmqSvyi5lHDKYz2slVSs6pWB5Q8kjmTEclfqimoRDe-ODI6IDShDKS4HYctJ_IeL-6Ah8yI3jMoboSIek8r9SwxZ4I5OAwtH2frqf71O76hb04CxJMVDZHheLgHM35Xbe9AzpjtCb31_ju3iSQxaieNHSAHWPxNXb4OeexrZkkN0W1r6H3uOSADVI7ePqt6J70RZCXpT2RbCSeFHEC_9GqDybCkT2QT3Nt5svim0pHyMPyHxk2XT3LoMLyt2Hhmb4=w1134-h626-no
OTA_PEfvprPnasrxjLromPZqnW-_Ip2DCxYZ2K0967dRrh1y11w4fyQOSvZ7gEUneog2E6qD9DV6AKK4wxiZ3HKugH6BurhxNwpGOCjVamcgj8Bka2sJ6q7WWbItNvHcqjD7N9VtWVvDhft5k8buNX_r6baYHtN-jhUqVGIe6seZ5N_C8WuEy1Z_KvqkYgoIQSRQKc0XSPvKSUNT-pSTKJ-hBC1K-jDbPMHPTABh-JpVtFnUEoZUUoRZbmcXNFv0NILLubyyKvcGHUkVZTkBWSX6W93ktU3wqvNFePPrynv1q10H5OJQn5kqj8EF5k5lxU2TzEi3n39qhdfenpVWP_7RD4FqTa35wftU9A8np-FJlR9O2BJmgBGtJYZ45Rtt679PquB6q0pmrIpu1wg0WHB7LoIdpeF8XNtjrfdoFToVC-hlnIXojrdGoZCZIeeITi0h3R6_UPjJCcPaNxl8MbtjoE_IgqH11i0m87L1kRe3-Fo19u-JbEwZ5QaOQDksugYRPBmdGTYxZAAjluMrLPESKD_ehqtZKxflplfnJ4Cr5aMAKhpgYvDvnxMM-iMsND3MHQnk3Va32DtMdxtWo_u8bQ_mxI5mQE3SazD9fY3SU26sb_0CCJZukeOxubrddYKURvLozlnGtaspv_-n2ISOWFgNsZ-dbAsQta17Tm-MbeGBOgpZ0rvelAl_ESuqz6XSRDlZEMPgSUAVH3E=w1012-h626-no
Pnw8qbdSBD7KeY_jkr-ew50JEP5tbTbpokqx-7NJXGIjDJX3VRuhOz0fjP7L1hxL3jV9lCmIRyP_F3efN-lMHcmVVYllOGAsW4u8fHfPhPrdrfNA2Tsge8dgddPT4aOwLa1hAxYTqhpMAde-82vv42osfDw1kB31JGfLJ6JkITw4HH1XUXdVusNn2-d7hJlw9MPxDF91p5EsAAxWrqiSUcy73BZrOG_b5wUUvl-PdbA3RE0R5Xlxl6N_iycSh2xq_DzTFntgCKlX_eW7T2k2pwjVNc8_wUVorTeteIk1XfCgOFoezGOyUmIkj_VNSjdNOb5bO5ylRGSyV1-72MW9erMarDaFDlFASCv6WfpWcg3VUiUDc_Llh4QG-ccwSLQJeGGH3mkbb7JioRwJoNsbI2UNg9QQtJ9d24dTM55tkGSrra77U37WsT5bY-MRBgntLIFhFTuAV5Yf7cB6SUj9Mm3uQ-NZAL3eaWZkyQVyMH2szEp5NpItMRLYjR0EOlKh6EsJ0-L0Rdb_i8gjLQOBStoxbIBC2oQCBoXPAo0nJmEGB_xxO7GQlH6kg7qtUkIFWU67lSihJzOZRyCiSF5FDYhW4EBMMnfbsuES4BdHsN1frC1_UBP6cffepyTWPB-aiYFO3KkqmV6v8o6tRvHSfZJpB8Ler0MvNIHsPzAZw__IvJWz2bcfir8mUGjBS4tgC5m_snU9bQT7XyTdy4E=w1113-h626-no
aV-aThG5qmi6nOQjibtjgVW0WzwQSG1VV4OkzqHfymlUM2Sm4GoLYT2Hh08qrj1fih4gFmOdnw7EvkTwKF4hcThcnAhTTRBa5CAK0VvZk7jGEOXaJiKbAmEamn-e_YX-zpT2ZksYgKmkJIrNqZMZsAsirtW2aXa0EiqOexNCqQSGFcuBJlkHs3ddbQyybXXPSslxEoFmoce3Rfi-0lnh3CgLVK8rqjwy_wX5DDZQRNPYJxCZ2Eyh6PhBTQ-duL9sWhKpp0W_2yvTgZGVO2c2r4aXhQyuQ6JznxMdRdlA-WP7ulK6Y9Z7gf7oefTRIFtFZBF770BzM_YO_rhUgNj3v26FOicGmDs1f4V3gkK4PdWz8q4STg1wBq8RAHVbJTUAJRaYG3pXUvlgmTQNlJbbPX6nis2zjVU9BD5Pn8xfjAB0T0CW-QPJXaq38aCNl5qFDmwDP4mazI_k8AT3PJy6lj4m0KkoVLdH2fPNlVHmg1tDOQUOVT5LjpXJHuhIuLaSJSyvOBpz5e4z7mvUjdt080T4gj5YJcHNWKRkmkQEkw-LRLTlc6HXNndMqbsQ_lqf2oiENTx4fwKCA_jYZtO-sfWTqLv7YnqtpPnXzs0_Xkz_w7AYWMsyyvt3NAMYc0CNs8UdOWik2FpAGMg2PNYXQ5U9f1EUB3JUyMr0HEdj8aYOywICL8XPEwYE2IpycquKdba-Mb6_BWYLC5dnGys=w1113-h626-no
LD5oFxGMLpGsZdZjpqwlmZ2D3uR-WLA_VvNieR5R52v7R3CmBdCvzNy6yrjvYpomCFvErBHiTeKLHs8nZ--M3irccDlUn9HAMV-h0MaV84wL7gUQ4xCJjQ-J_pvYTq0EG0-B-p9S2zuWu49HsVa_m3fjrtRqtISsRkQEpAzVq1GBWOuXUxJw7o5objxEHpoNR8BTEZb55NcFfPuHoUzpvR0SLVAxu-Nt_aRFkJdUMri1ULIrk7v4k5RXnM6WDUJnQzGyMC5trYThA8TZVg7icpQwf4cV-K2so1BkpOexeogjdp-pX1AJ3FKE9OUe_7z9VbrnKbhUxPj86BAM8cfAxLybcbX6XYn_wzU3jLEebUDkdBqW4ihDgum2qIqCDDCZ3AKnE9kCnPqz3xk5n1xG4zh8cYhyUzddDs2d42PpLBx8oe9xNsJGdWUE0wwasHd5g-GeW2kNoHBfM-vQEaXYnfd4vD8nDqwpXmT7hElDcFHKxJhckhEdM4EkUNSn-WiEuQFTywB_UYyyXSvylTYtlOyuIvwAq4USXiqmoMKoBgHmF9lhqhJ58L2prQwFuXMvALkOiXXe1hZuEvMmJOVHzcE9Z6QHYdJ2Gq_apwSl3agC6XA3nY2THx6nWZJY7zylvnDFHxLE-FYV4PKgISjD7mT8PpPk7IswRAgoPhShsRfKXolryGkJ35gaNHgVFuDF73x2SYWPoXe6n3o84fQ=w1113-h626-no
V2kQOlAo9NcDoR6oOYr8rKPAypWoxsMZqskF6jRAZjn5V2TfmGcvAGjj_NhUsJUWs-QbmBl8X3qhm0V3pLpOPOzDVTVb_2ZJzmhEWNqcFBQe_S2XunCM8HdAlxwqCOJNbnwcNqXBCLlzj2cQsO_KnLkMzLo8iocPIo7WBCYVQgLd3eMsCmgXUsYQ3mWOThMQqf-hAUYZa7MSDxxFz2V3mBj_PbG5oAUpntVTm7Mt0_2NiR5_2ssjgeV6MTsQUEdfRFl6bv9ZFAYOd4VyuL5ltRurJtzO_heOaeotGXd9HAlCpTVw3YMkcp-t7EdMstwBDLghr5OGiYSfmwlG8PsgxCHv2A7Ft2KJxfOatOVmjINanhzcIoveQlZiw_Em3WDrjwEaWFPHjcvQ07CpWp2WPTW9B9eezPSRdg4XZg1quoVlo3gXW7AAuwjdfshNC-Bu5tpf-uWf4Bq1PSkplcCHR5zYgPf32Xudd3TNNd6pTR-wkgwRK3939x_DVK7CZSfZEiOxG9Y3zWwdEoDc8Cnx0iDqXVWiy8BO5WyN37vO1ADRzzrBBSbBosZ1dDGvd2p7Tkz6l-y17NNaf8aM9YnZI4o8bx7K86ZwATK5Fu-G7cVxrtMGodxOW_Yp0wx0iVHDphSTDcRdcRXzQfJjSkY8xFANlqUpQX7FAhG0rdSmJ_3sQtfjuBqlp6G7Vgx65wH4A4QVrn5jnS_VcqyjArs=w1113-h626-no
tdc7Er2ZJ1EYGpw6-spd_zDBWqxmxR5sV8_8P1FA7HA3v6xUqx0mexjbHUnY2m1KbTjA9F5pkJnPxVNFn8EiTZWlEgF9RD1kYn4d7FuxDSBLNks7tT6qVe2CD1KGdZ9GiXOWL8tQKUYhzRYPiowgzo3SYXQ-qhDmwRt1kWIwDb_kDajnW6mysZ8gUaIGjr65m6Gmqqced3mOvXuRPjCi1wWLumvBzmzOftvk0F30_vemoB5R83Oz1ZEaHrU2r6OBMHi0qeKof8Gbg5X1EymAepdW96Juxe0HfbCP6nExdta2sz2LThbprGvZOT5syFxgfr3CfMXDsFbvPxm9xi8DblKjMh-f5qCWl-h-9J9Uur8VojotRCo5PclySw1IGBrbO0dgMmRZ2ZiMWLsWWWfSZoE1ya-wumakp3UT9Jbb9inhTsrAlrgIHvjfjVNCE44sEhGXCYoIRB2K4UdtUokCEGKP4FV0BlAWSvpJCiqwkpWKxpXgM4f5XeF9h7bYm-gV2NUMHugEzhrXCkYU1q5cM7Pd_bK-QqrxQaXwWXtfGCZik6w8Y_DBrnC9tURjbVnxCDCKofCz07Ay_9wzsg1RYjmkq1bGtoBt9mJfOZarYHa9IgBVYxBHFnSdKQCAgL-tSX7gS5Q4gNp3v9gIqdmGNLbvS09UZ-g05eY_nwn1KKwY-r3GOH8pKOXupng1z51QswWLxf5dIUttjkk2jKQ=w1113-h626-no
MHrK-6p3BqthuCIvZQ-4HvDBQb7Xf_V6BxRhkcd9D08w8mayvr8eymqAJLISwJAdeTmvUArsZIVNmhW0o-WxN_Z3o0qA6Zd1LiMRFzPSvxYVQGUatNqfRVnH549ywvNUarJkJ9ur4QUakZH7boNxgcTqlUAWDGaCE1IZAj4cwhNQd5fXV1rC5Kfh6C_dn3Av4JF-93V7ODgLuJ5Y5aOpQoxhynMj7E6a_VFRYsJxJPXXQUQ37ySdiKkTND0fhQ-gl7rKu3PHiZ2b4Q287syMbzB8zYsjfuwfoa2FlT4DXN26rx4FaoXZXMTNpoOLhDeJrj-GCwdyS1cW9-Mc9gNBcBNc-X7GcO2ZMIypiLnirmVi6nTqphJ5J9AUgg2V0qY1kHd_08DB08FkK5v4-JqMVsJ1bcJXVDYe-9LkZkhl3yHnKtpm_B0ZolY6MMvOoNO6cQOJmTJcncDBi1ptcItfdBR4PHqScA7vcb2WxEbgT7WSsXOndemgDQCtQC0UogBbQsTEIh71PVytJD6vZUMO4izNWv6ESrrKj9WsJTO2IyDofqTK95jxvcvXs9QXPoonIdU3WvrpdRDNsKAJSxmLQkG5Qq-iky-skcHtNUFNOMV-wF4DNnEp2nef1chbWcr0-2Wu_h4OzHloWPdZuSmmQA2alcaRYYpRzyngISSLWnZIWtJmaMHMYQjtscFUn6ng_Oe6-5QpVNGGu_yDAgo=w1113-h626-no
VhkgWwVGfC37lOZ2mtbIObOD9ctKKdcptrRKo8CyllyG5xxAvwE0LBiTOdm3IHcgf9nZc26lNDbeEHe8KAG9063nTRZDiZl1cecUnctQRbaTj3S6dMfbU6lpoJVL2BhlCvLNRxzGWIRMpJxGYKIAMBWUgaKO6HsMqnK7dMKaKZhzm-XDJDDdDJ-3Ucya8j9USVfHrv3Emk2RWkt0HAYa2CwjYhGeWQOss_dK_5V2RE3B2ucNOZdxS-_Un_1ZHbmeObbqzChzePuJJbQwa6YozBIvfQx0mWdlxgBrWitAcVXimdGWOUxRxCZI8z7yIORJJAvJsZEfg01-GEkAaRko6k5pWSTGj9qEeTUnj0A-2uGOWRpF9WoMSgqyGeLru6gvkeoZCFW9ts4pxVXAAaS5vZ7Q8NqhVMNenVUSkm8k4MpArMwWiGka4-oorvu9mIvUpR6piJt34d4OC8oCwQkMLQnAGy4SaNjgs9MzGBW3fDaGuZlGSOAR-EMeNutcefGz_BezThNeM6YpuuOox-zb8hmr8z2H4QB62ZOzM6J8g_Bo69hm1Mds4Bc5Evo8ES-skM_E2BC6nhvHAPhbOZ0G5uD-iicjEmOHKZ-UtN4ia-40oE9mEy76AWKBuxVPPatkG7cyl9QX98XEyASO3B2gqmu6AkEyMQgZl3BKah004xg9ZAGOAs_mB6rS8wGafmJF91TTMalDkwbBDXt2Sqg=w899-h626-no
R3SZSR_z4pkn4I5gnYkMEUbJrG13XnMxKea-Qwx7FPiZ7E1mgqNwHnYmMZHkNZd80fp_aaJnYmRGvKtcRhGeJOkcfDbrusmIUlpnaqSK_TFcSQg0A2EjHJkZNpa5rWIpqloOkgJkQfbah6vRuJY71f4eGclcUT439AHE8U40SIgTIe5-1UkPBQLB2yvVYqZi_JMmoEJlyS4O08ju6QZNNLDsU4v3sfo6u3Szgk6PS5Wi1oK9HS48n9rVgor8QyRRK9AZFjHj6F59VB7cQjy_6-OflFB9MEIF0QjXEhEDOK_iEHU0sDrDsbeC3ARb_erLpYI1v3_cLYsAlAiMt6mnGU9SgfXx78ASi8l43TZtF4rN5OIE2k4uRUqvg-lDMn1oseWLtyxxG94sAFS2_iVkiYMPzIzb9nZtj3V5hMddHd1t0xDbSQXjdmP8f5qzoy-IzWZT5it7Fu1dZ0TlBOheYaQa3ytRefeQy_OSpk2RTCnilpJrMKgI9o5YlHUlCY1MvsYpxKe4euqNbjDBsonKSNfjKEcOiejCPC3j0nZ_vDPo84f-VnxBn4VLpZXc-79-bl6eacSn5ZCVAxmZXzYw8bUzx6xj0LL29G49dKJ-0ybpYaHO8kDP4qaMXoOUDd30CtvFemi3jeB61hJjaxuomZimWDnVftC83GxrTx15v7Cw13NZ-4h_yz9LFzeXI_51x0XsNOTwPvm4Vybnx6U=w961-h626-no
vQaqpwbbOhjbtaC60KowvIaY-ft90oyiF2qb6tzqvp1WPGrb2YC5ez_4hHJciYBX4apIFijs47dNshOYMMtZC4mo26ZQNhmC8sISxpqX_UUDqD3fAE7GBkqHW6gAEtltSh26I28zXOMPuGeXNRtLz3BBqXEwxgs-uhRWblH-r3EZYNp4njtWaAzutDk29oXOdRfjpQVME9-8SdwtbvzTHZuE2oWQE2jSDFYnOKDjw3H75LYJ8rQHAMnV6XlLNEZCJM4TEfodIqrFggM6tfd2JlDVYVYxcdpaJ5-khzbfDcuMxRukDk7r6LGbs753XoYn05suj6TUGR82vWCFBqqMujlMn72qW6oG0nMlLkqxs76Ru39AFtLUTqfpm39eQ_Jd5zybAlVztddv8epZLVaS80ehTXStibB3GxQ8eCQm8vc1fKz6h6OQTKxMXdr19mNDQRZTERaF1N-UIjNNlkPrLC5_ZzavwoNaarGhLeDos4okylvwvqp6jQx0Ushko6tKcH2Al5c0ei9Ryqws0Oj6TxL5vLOaNzHS4iwdQMnsIM1JP31hLaBcVOxywghFsjMqhxZoDqpUQtpF2TfJZJ4aH63IaY0YO9ZT2G5ZexazhVnoHcUckPKL6u1QCGAudlCovfA7jqLHTwnsnwLaX4xZjT_HQk1XAnZORTewvmHfCoa-9US9hHJFpf7UsfQZtvyj9zl68H21syKy5fhnxRQ=w1062-h626-no
PfvsJ_vCVk2vN4fnoW5GNkqz6bWPGZJqIXJ0uQSTvxaQI_eFW0HDy-ofBAahhV2CqsiVsM22WP1C2nOiAXSCFOSN9tVG0C6JHmMtVAJNVWeOJIUbtnqhIhy5pYSHIjOB9yhiUM1-7uSHd6FFzsN5eHCfKBPXIr6lM84SiflKgy9PCZxaTBP9cxemdLDTbr67dXc5-yPjguv_TOMV8qPyEryO0nLzFgKFhXEugYJ0L6xzeMlPyyRBs_fj458vmIquvc-kZWcdhjtTf9a95GDIej4o1WdDBug5MUCkouQWp1A8IHx9MRw9aOUH5nToRbfUzcqKlv87zlXwnvQcU80a4__u4BlksoyYNUXxSdco54NaXiarKgqQE-FPDFBYZ1cjGcg8D52WP990O0XjpAj4yq0l8EDA766KuCvXYd7KMLeO0BDoe36rE_VzaYdXf_VR7glebI9-Zv_Aji9sW0xsABA1j-vgzp11widXxmVLxIjmSxS2NhKTgqeLj4ThB7uIt4KxIGSS4kiaGLtVmIC96JzN1csKn77WVkClRLbJg-R5xLUpQHuxDn4IJ5koffBMIpCoFBqL8NWpCK_oW4-CPdipDoxxZF-dZfieTybtiIWXrFZUvAmBIVqWtaDXuqAZDujtTnT73mztXes3x9A3IgtPZC2hVyldaiEeQci9MYwu9oTnfIvZ6_FGnfwYPe1qQuKdbrUk-A7UsCMkHpk=w1113-h626-no
