Bolt Size Question
GVR47111K
80022, CO
I think Diego might have posted something similar to this but in another section but I don't think it was the same situation I'm in. I need the 4 bolts that bolt the exhaust mani to the turbo and Mile High Mitsubishi wants $80 bucks for the parts. I'm pretty sure it's worth it because it's OEM but is there an alternative? Can I use anything from a hardware store? The part numbers at the parts department are: 12739 and 12797Q if I'm not mistaken and these part numbers are also worth noting: 12779, 12739, 12763P. If anyone has any info on this I'd really appreciate it or anyone from CO with the parts I'd be happy to buy them from you. Thanks.
jepherz
KC, Missouri
Nope, use OEM. You can get them from JNZ for less. I've even had bad luck with the ARP versions.
GVR47111K
80022, CO
Thanks a million!
