Best paint for hood?
mr.mitsu
canada
I'm planning in painting my hood. I primered it and it's all ready to go /ubbthreads/images/graemlins/smile.gif
I want to do it flat black and I removed the under-hood insulation already. I was thinking some kind of high heat paint ie engine or even BBQ lol
What are your experiences?
Thanks
EHmotorsports
Beaverton
Really you are limited to the paint that works with the primer you used. Mixing brands or types of paint is very risky as its a 50/50 chance that the top coat will not like the primer and wrinkle or peal over time or instantly.
rdomeck
Indianapolis, In.
Look up SEM Hot Rod Black. Has very little shine and can be purchased in flat I believe!
mr.mitsu
canada
Thanks for the replies /ubbthreads/images/graemlins/smile.gif
I'm more worried about the high heat from the engine distorting the paint.
Should I be worried about using regular flat black paint?
rdomeck
Indianapolis, In.
Yeah...Don't worry about the heat from the engine. You only need to worry about high temp paint when your painting exhaust parts.
