Ball Joint Confirmation
atc250r
Orange County, NY
I need a confirmation that MB241883 is the correct part number for the OEM joint that will fit the front control arm of our cars?
John
atc250r
Orange County, NY
Yes it is certainly a ball joint but I need confirmation that its definitely the right one for our car. I went to cross reference the part number in CAPS and it doesn't come up so I can't verify by model code. AFAIK Mitsu does not offer a front joint per say but the rear ones do fit in the front. Unfortunately I can't find the rear ones in CAPS either.
John
Rausch
Cleveland, OH
Can you cross reference with aftermarket part #s? If so Here is a pic of the ball joints I used to replace the OEM ones with. I bought a second set to be used on a pair of control arms I was cleaning up, and wound up selling them.
G
zompton
atc250r
Orange County, NY
That's the thread I got the part number from but when it doesn't come up at all in CAPS it makes me hesitant to order it without someone confirming its the right one.
John
turbophein
mass
i just installed moog ball joints, which are probably better than OEM, i use them in my lifted jeep with Dana 44 axles and 37" tires and they hold up great..
here are some part #'s for different companies
Moog K9617
TRW 10371
Chassis Select BJ3901
Hope this Helps
atc250r
Orange County, NY
Thanks. I know about the aftermarket ones and even used a set of Moogs in the GVR4 I'm pulling the drivetrain out of. I'm not a big fan of any of the aftermarket ones nowadays, its hard to find a set not made in China or Mexico. The Moogs I used last time were made in China. Maybe I'll try the Raybestos Professional Grade ones or the Mevotech ones from RockAuto. They aren't super cheap and maybe they're a better quality than some of the junk that many replacement parts are these days.
John
Struc
Oconomowoc, WI
Quoting atc250r:
Yeah, it doesn't come up in CAPS because CAPS only shows the full front or rear arm as an available part. In fact, that part number doesn't come up with any models. Maybe the newer Mitsubishi parts program has it in there (can't remember the name of it at the moment).
The original component part number for the ball joint is MB303526, however it is not sold as a service part. It has an outer case diameter of 39.7 mm. MB241883 uses the same base case and has the same outer diameter. The actual stud is different, but I don't know how.
MB241883 is still available through service.
EMX5636
Bucks County, PA
I just put the MB241883 Balljoints in my 91 a week or two ago. They are listed in CAPS for the Tredia. I just rented a balljoint tool and they went in/out without a hitch. Took me less than an hour for both.
Justin W
raptorWagon
Oak Harbor, WA
Quoting Struc:
In Mitsubishi ASA(New CAPS) it doesn't come up. I believe it doesn't come up, because if you order new arms they come with the ball joints already installed.
When I ordered new Rear lower arms, I thought I would need to get ball joints for them, but when they arrived, the ball joints were already in and ready to go.
Armitage
Herndon, VA
FWIW all the auto parts stores I checked didn't list a part for replacement rear ball joints.
The rears are the same as the fronts. I recently replaced all of mine.
