Alternative FP manifold bolts
4Grim
Orlando FL
I bought a FP manifold from a local guy and he didn't have the 4 bolts to attach it to the turbo housing. If you are familiar with this manifold...the OEM manifold bolts are way too long to use for this manifold. I was going to order them from FP which they call them Evo bolts and the $8 price wasn't soo bad. I found out there was a minimum $20 order so I got a couple other things which my total was $21 and some change.
Well checked out and their only available shipping is UPS ground for $21.00 /ubbthreads/images/graemlins/ooo.gif/ubbthreads/images/graemlins/banghead.gif. So basically for 4 bolts and some other studs and nuts I am paying $42 ....which I can't justify to pay.
So my question is...:Is there another alternative bolt I can use for this manifold that is the same as the OEM bolts in quality and heat tolerance wise but short enough to bolt the FP manifold to the turbo?
boostedinaz
Scottsdale, AZ
I know that you can use the bolts that held the stock O2 to the turbine housing for the short bolts. As for the long one I don't know of any common bolt on the car that is the same size and designed for the heat.
4Grim
Orlando FL
Good looking out Michael...I was just thinking about that after I posted this thread. I will have to see if I have any extra O2 housing bolts and give it a try.
Street Surgeon
Omaha, Nebraska
The FP manifold is designed for two O2 housing bolts, and two of the regular turbo bolts IIRC. You can order the bolts from JNZ but CALL instead of using their website. That way you can ask them to drop it in an envelope and ship for like two bucks. They've done that with me for a few misc gaskets and/or bolts.
