Alarm won't turn off from drivers door
gijoe985
Active member
Ellensburg, wa
So, it does not seem like my alarm will turn off when I unlock the drivers door, but works fin on passenger. Is this a common thing? Should I just dig in and see what I find? I found a few articles on disabling the alarm, but not so much fixing it.
I have to do the same, either passenger or the trunk. I tried replacing the door lock cylinder switch (tested OK), but no solution. I figure there is a broken wire somewhere on the way to the ETACS, but I put on a keyless system and it works. Basically I use it exclusively and usually avoids any alarm problem.
matt92vr4
Venice, FL
Same problem here. I have to unlock my door on the passenger side everytime lol. I'd like to put a keyless in. Which one did you use? Do you like it?
toybreaker
iconoclast
... been awhile since I had one apart, but inside the door are several elecrtical components of the alarm and automatic seatbelt system.
iirc, there's a pin/microswitch/magnetic dingus that senses the lock cylinder rotating, and that's what sends the alarm module the "authorised" signal that disables/turns the alrm off so the door can be opened without triggering the alarm.
I've seen a few of those knocked loose/floating, just waiting to be reunited with the mechanism.
rememeber, the interior door panel/door card is removed by getting all the hardware out, and then pulling up, not out!
If you don;t find anything amiss inside the door, another place for problems to occur is teh wires themselves inside the flexible boot that passes from the doorframe into the body. A good place to look if you;re having other problems like in-op windows/doorlocks. The constant opening/closing of the doors flexes the wires, and on high mileage cars, the wires finally fatigue and begin to break strand by strand, untill finally, there's not enough wire strands still connected to allow things to work properly.
One final place to look is in the door/body harness connector, (ircc, it's easier to get from outside the car by removing the boot in the "a" pillar, and then pulling the connector out where you can work on it ... lot's of stuff in the way to try and get it from inside the car) Water from a a bad door boot/leaking windshield has corroded more than a few of them, leading to in-op door circuits.
If any of you guys do troubleshoot this and find the problem, please take pictures and report back what you find.
... be nice if someone searching this subject could find a thread where someone reported the resolution/fix, (with pictures!)
thanks!
Quoting matt92vr4:
i just used a commando cheapie $40 system, and I only use the keyless part, as I don't like flashing signal lights, etc. No alarm either. Not too hard to wire up other than getting to the ETACS which is above the fuse block by the driver's foot.
commando
matt92vr4
Venice, FL
Cool, thanks for the link. I wonder how hard it would be to swap the guts over into the new EVO key fob?
SouthCaliVR4
North county San Diego
The main cause of what you describe is the switch falling off the back of the door lock tumbler. Remove the door panel & youll see a whitish conector dangling just below the lock, they get knocked off by slim-jiming the lock. you normaly can just pop it back on.
