AEM Tru Boost help please
I've had this BC for a bit now, and my question relates to setting the waste gate spring pressure. I am running a B16g internally gated with no boost control solenoid. Should I set this value at 7? (Value of 7 = 7 lb spring). I would think so, but input is greatly appreciated.
Nate? (Because I know you have one of these)
mountaineerjeff
west virginia
I take it you mean when setting up the electronic controller, it asks you to input the waste gate pressure. if so, and you do have a 7 lb spring, then 7 is the amount that you would put in.
