Armitage
So the story goes like this... In the spring I took my car to get an alignment. The shop, while trying to break the rear upper control arm bolts free, managed to break one of the welds that holds that little oval retainer ring for the eccentric bolt. Okay so that pissed me off, it's a big project to fix and they basically told me "sorry, come back when it's fixed".
So I got a whole replacement rear subframe. Into I put all new poly bushings, a new 4 bolt diff, new ball joints, etc. Over the course of a month or two I got it all set up and put it back together. Every single bolt antisiezed and torqued correctly.
I took it to a different, more tuner oriented shop today to get it aligned. Guess what, I don't know how, because none of the bolts were stuck, but they managed to break one of the welds that holds that little oval retainer ring for the eccentric bolt!!!
Now my 3rd rear subframe is boned. I'm really getting sick of this. I didn't just put in months of labor lying on my back under the dirty car in 90 degree heat to have another shop break it. Are these things really that prone to failure? This time I'm thinking I'm just going to get the ring tack welded back on and call it good. It's a really terrible design IMHO. But since my camber is completely messed up in the rear now (like -4 degrees).. It's probably a good time to get rid of that awful eccentric bolt design and get some real adjustable arms.
So, does anyone make/sell them? I see something like what I'm looking for in this picture from the rear subframe bushing thread:
How do you guys who run these deal with the slotted bolt hole on the subframe mounting tab? Do you weld a washer in there or something? I can't really use the stock eccentric bolt anymore because it can slide all around with the broken ring.
Thanks!
Thanks!
