jnava
I've had time to accumulate a few performance parts with a the main goal of having 300hp on my galant. I feel that having this goal is very attainable and will create some issues but will probably be minor. I've seen how many of you deal with such issues and I feel that eventually, I'll have the same problems. I've read many builds on the dsm boards as well as this one, and I've learned that the SEARCH button is the best way to find information. With all the knowledge in this site, I still feel like a jackass sometimes. But as of today, I installed my e316g today and decided to pull the headlights since I have some jdm headlights I purchased a while ago. I do have a evo 9 fmic as well and I started to pull the bumper but left if on the two bolts until tomorrow.
I have a set of comp cams 101100 aka fp1, I want to install them myself since there is a tool for the TB tension, and I've seen the video of the changing of the cams but I feel I gonna fudge something up. With many of these parts that I do have, I am missing some injectors and a fuel pump also but I'm not rushing to kill everything with one stone, plus I do have the v2.5 dsmlink and I just received a Bushur/sx afpr and gauge. Everything is coming along, now that I have 2days off. I've been working 6 days a week since Feb. Everyone has been affected and so has my car. I've realized that I don't want to daily drive the car anymore, instead, I want to fix it in a way that it runs great and at the same time, taking real good care of it. I have tons of work to do on this car and I've finally starting to realize the pride of doing your own work.
So I started installing the jdm headlamps and they pretty much fell into place except the grill. I do recall hearing a discussion about needing to install a jdm grill as well. So now I'm in the hunt again for more parts to finish this part of the build. I actually followed the instructions to the "how to" on wiring. BTW, I did solder and added some heat shrink tubing to get it done right. Here is some more nasty pics of my bumper,.
I pulled the bumper off to start checking how I'm going to mount the fmic and realized that all the how to's don't specifically mention the mounting method except, "it mounts in the stock hole locations". I need ac in Texas , so I can't remove the condensor fan. Probably be best to cut the support just for future upgrades as well.
After reading a few of the other evo fmic installs, I decided to cut the hot side inlet pipe. Here is my problem, I have a mig welder, I've already purchased a spool of aluminum so I can weld. All I'm missing is a argon tank. Now, I don't know if a 20# tank will suffice or should I get a 40# tank? Obviously, I don't know the standard amount of use of a mig in comparison to use of gas. I went into a local AirGas location and their recommendation for aluminum was pure argon or argon with some helium. Oh well, I'm going to have to find some aluminum scrap to practice on before I start welding on this piece.
Well, I decide late this evening to install the Buschur AFPR. It was to damn easy since there is no need to make lines or attach this or that, plain and simple. No wonder Buschur asks so much for this piece. Simplicity.
Well, I just won an eterna grille for the galant since the stock piece no longer fits. I won it for $64 so I think it worked out well, even though I should have bought the fuel pump or injectors, but this pc will probably not show up soon and I think it would look attractive on the car.
So the eterna sava grilled has just arrived and it looks great. I've also purchased a new set of Fic950cc Injectors. Here is a pic of the grilled.
I also just installed the egr block off plate from STM...
Here is the pics, I've been so busy that I haven't had a chance to install but I have them ready..
Well, I have an HKS EVC EZ boost controller. I just purchased an HKS EVC IV but just the unit w/o the cables or stepper motor since I already have the pcs from the EVC EZ. After careful consideration, it's a direct plug and play so it is a perfect upgrade for only $35.
The interesting part that I have to decide is if I'm going to install these springs and titanium retainers and I have SS valves as well. I could do a some simple porting and install these goodies and get a valve job to finish up or sale them to buy a couple of other mods. Decisions, decisions, decisions.
Well, I've been a bit busy and lazy at the same time to deal with some concerns with the galant but as of today, I did a walbro 255 install and also finished a fuel pump rewire. 2/1/12, I was lucky enough to find a AEM Uego and I purchased it. So I'm going to purchase a bung from a local shop and install it so I can run the line to the ecu. I have to research which pin I can use to log the aem unit but I'll find it. I just need to get some lower injector seals and drop in the injectors and do an initial test on the pump and start getting ready to start tuning. I've been reading up the ecmlink wiki and it's actually fun to read how to understand how an ecu works. It's gonna work or blow up...who knows, but it will be fun.
