I was told I could just swap the ring gear and pinion from a 3 bolt rear and use it on a 4 bolt LSD and housing.
Well, you can't!
The ring gear from the 3 is waaaaaaay smaller than the 4.
Now, I'm stuck with both rear ends in pieces and brand new oem seals in the 4 bolt housing
What I want to do is put the guts from the 3 and put them in the 4 bolt housing
Is this ok?
FYI, I'm still running the stock tranny code W5M312VXZ
Thanks
Well, you can't!
Is this ok?
Thanks
