16g?
tintoy
philippines
Im using a big 16g jdm gvr4 and planning to upgrade to a big 16g evo3. What are the difference between the big 16g gvr4, evo1, evo2 and evo3 turbo? Is there a big difference in low and high power between those turbos? /ubbthreads/images/graemlins/confused.gif
LIV4PSI
O-H-I-O
The EVOIII isn't a huge upgrade over a big 16g. Unless the price is right, I wouldn't think it was worth it.
Tre3zy
South San Francisco, CA
spools a lil faster and flow a lil better... like said i wouldnt upgrade unless you get an evo3 for a steal
5OF2k
colorado springs, colorado
It's a fairly noticeable difference in spool characteristics over the standard b16g, but not enough to warrant shelling out the coin for a E3 16g, in my opinion. Which hotside are you running with your 16g?
DDM
Palatine, IL
I cant even tell the difference tell you the truth. I bough the car with a big 16g and now i have an evo3 16g.
LIV4PSI
O-H-I-O
Alot, the EVO VIII turbo has much more potential. Its not a direct bolt on though.
Specter
Karachi, Pakistan
Yes its not a direct bolt on. I am looking forward to do a swap to evo 8 16g after few days. Lets see how it goes, will post up a thread.
tintoy
philippines
If i port my big 16g gvr turbo x manifold, compressor housing, turbine housing and 02 housing will i match the e3 big16g?
LIV4PSI
O-H-I-O
No, the difference is alot more than just porting.
ktmrider
Tempe, AZ
^^ This, search what makes an EVO3 turbo and E3 turbo ( hint, it's in the center shaft and exhaust wheel material ).
alansupra94
Wayne,NJ
You can leave it as is to be honest. The only thing people usually port is the O2 housing IF they didn't get an EVO3 O2 housing as well as porting the manifold to get it to flow more.
tintoy
philippines
Is it ok to match port the x manifold to head, compressor housing to turbine , turbine to O2 and o2 to dnow pipe?
