1 count of knock pulls timing?
fastasleep
Christiansburg, VA
For the record, I'm running 11-13psi at wot, not 14-16psi. Prosport boost gauge > Defi d-series boost gauge
So, to me it appears that, in his logs, the ECU is only seeing enough airflow to get him up to about the 11th column, which would be ~10 lbs of boost.
See, that makes perfect sense then. It takes 14-15 psi to get the ECU up onto the top timing map. Between 10 and 15, the ECU interpolates a timing value from both columns.
