Super VR-4
JDM 1990 Galant Super VR-4
Specs
Ownership Status
Currently Own
Year
1990
Mods-Power
EVO 2 pistons, HKS cams, HKS cam gears, HKS blow off valve, Greddy belts, custom charge pipes, exhaust manifold with heat wrap, custom exhaust, custom carbon fiber air box, custom fuel system with trunk mounted fuel cell, all steel braided AN fitted lines, custom spark plug setup mounted on carbon kevlar plate, custom front mount intercooler, oil cooler
Mods-Drivetrain
Stage 2 clutch, Cusco rear diff, Ralliart front LSD
Mods-EMS/Tuning
Autometer fuel level, fuel pressure, volts, water temp, oil temp, oil pressure gauges, Blitz boost gauge, Pivot turbo timer, Greddy boost controller
Mods-Handling
Brembo front brakes, slotted rotors, Rally suspension, 17" two-piece Racing Hart Type CR wheels, Nitto NT555 tires, carbon fiber front strut tower brace, rear strut tower brace, custom chassis bracing
Mods-Exterior
One-off widebody, one-off vented hood, one-off GTR style wing, one-off fiberglass hood, one-off grille, custom pearl white paint, shaved rear door handles and fuel filler door
Mods-Interior
Carbon fiber/leather racing seats with custom embroidery, takata harnesses, 8 point roll cage, rear seat delete with carbon kevlar panel, carbon fiber gauge cluster, shift knob, dash panels, custom panel with start sequence switches and push button starter, battery relocated to trunk with custom carbon fiber box, custom trunk mounted carbon fiber tool box
Background/Plans
Built in Japan. I'm the first US owner. Plan on doing a bigger turbo and supporting mods, front air cups. I'm sure I'll come up with more along the way :)
Car information
Added by
ozlancer1
Views
1,216
Last update
More in 1991-1992 Galant VR-4
