look what i found in my turbo!!!!
/ubbthreads/images/graemlins/dunno.gif :mad:any one know what this is!!!!it was just sitting there when i took off the manifold i always knew the car should have been quicker! think this will make a difference in performance then!?
1941Galant
Charles Town, WV
It looks like the ring that sits between the exhaust manifold and exhaust housing (on the little lip) to keep the gasket from blowing out.
Flip4G63
Abilene Tx
looks like the compression ring. stock cars came with that. it fits into that ring on the turbo and mani..
IIRC its called a compression ring. i could be wrong though.
looks like some one installed a turbo wrong. and smashed it down in there while tighening the 4 bolts.
cOmpressor
Bay Area, CA
WTF MAN! That will hurt performance. Now you have to port the housing and trash that ring.
sixsixtwo
St. Paul, MN
just think, every time your turbo spooled that piece of metal came one step closer to getting sucked in..
its been in there since i bought the car! so iv never felt the full potential of the 16g that was set at 20psi when i bought it and never felt quick! iv been spending a good bit of money trying to make it quicker,fmic,hard pipe,keydriver chip,they never made much difference,so I'm just waiting for my new manifold to put on and cant wait to take it for a spin! should be different car! /ubbthreads/images/graemlins/grin.gif
ktmrider
Tempe, AZ
Good grief, at least you found the problem!
Mine was pokey at first too, found the original 1g mani looked like swiss cheese.
BTW I am in Ireland at the moment, planning to head west to Kilrush and Galway later this week for some family history exploring. Will hoist a pint or three of the Black Gold to your discovery...
steve
NJ
Holy hell you're lucky it stopped where it did!
G
zompton
Fire ring ftw! /ubbthreads/images/graemlins/applause.gif
jepherz
KC, Missouri
Quoting Terry Posten:
Flame arrestor. Yes, blocks exhaust flow like bolting on a 1" exhaust pipe.
They should have never used those.
I don't know, I'm keeping mine in my stock car.
I meant that it blocks the flow when it is down inside the turbo like that.
I would never reuse them. Do a mild port job on the output of the manifold to remove the old ring seat and also remove the ring seat on the turbo housing. Get a high quality aftermarket "thick" one piece gasket and you should have zero issues.
jepherz
KC, Missouri
Yeah, you may be right with the stock turbo. I've just seen so many problems on a friends car (Obviously heavily modded) that I'm going to keep it in. Car won't be driven hard anyways. Of course, that's another reason why the gasket shouldn't blow! /ubbthreads/images/graemlins/wink.gif
Polish
NE, IN
You can get the OEM upgrade 7cm ring. Someone on some forum with a 2g was very adamant about using one and he still went like 11.7@117 iirc with a Evo316g/Mani (Give or take a tenth/mph).
Can't hurt to have if you have an OEM turbine housing.
Once you go aftermarket turbine housing it obviously does not matter.
