IncorpoRatedX
I got my AFCO Scirocco style radiator in the mail from Summit today. You can find it here. I welded studs to the core support and uses universal sway bar bushings and washers for the radiator to sit on. Then i made a bracket for the driverside of the radiator so it doesnt move. All in all the install took me about 20 minutes. But my car was already apart. sway bar bushings can be had for as cheap as $5 and a 10in or 12in cooling fan can be had from autozone or the like for about $50-$60. I will run one in a pusher position. So the entire set up should run about $300 and some change.
You can also see my installed ETS FMIC and 2.5in polished piping /ubbthreads/images/graemlins/laugh.gif /ubbthreads/images/graemlins/laugh.gif
