Hi, here's a list of them for you guys just so you have it. If I've missed any that you know about please let me know. Lots of these aren't even in the application guide as it is and I've had to dig a little to find them. So, to the best of my knowledge here's the list with prices and descriptions:
SPF 1439K $50 Rear Hub, Front Bushing of Lower Rear Trailing Arm
SPF 2031K $70 Upper Rear Control Arm Inner Bushing
SPF 1343-xxK $8 Front Sway Bar to Chassis Bushing *xx=sway bar diameter in mm's
SPF 1344-xxK $10 Rear Sway Bar to Chassis Bushing *
SPF 1438K $29 Rear Lower Inner Control Arm Bushing
SPF 1313K $40 Front Lower Control Arm (rear bushing) no caster change
SPF 1314K $40 " " " " " increases passenger side caster
SPF 1315K $40 " " " " " increases p. side & decreases d. side
SPF 1315aK $40 " " " " " increases both p. side & d. side
SPF 1437K $47 Front Lower Control Arm (front bushing)
KCA365 $66 Rear Control Arm Upper Bushing (Camber Adjustable)
KCA321 $44 Front Control Arm Rear Bushing (Caster Adjustable)
W0623 $56 Front Control Arm Bushing Kit
W0624 $56 Rear Control Arm Bushing Kit
