brakes are done (pics, part numbers, prices) 5-lug convert
sleepyvr4
Key West
Calipers media blasted and painted w/ 500 degree duplicolor engine paint. Rotors are brembo blanks and the pads are axxis ultimate ceramic/kevlar pads. My friend bought this setup for his Si, and I was extremely impressed so I bought it up. I picked up evo8 wheels for a good price so I swapped in the 5 lug spindles (what fun). I bought all the brake parts from nopi - and the prices were pretty good I thought. It was $250 for everything shipped to PA.
5 lug rotors:
BREMBO Vented Rotor - L/R Front ALL 4WD Turbo Mdls. $43.38 - nopi part #437+0682
BREMBO Solid Rotor - L/R Rear - ALL Mdls. $33.78 - nopi part #437+0745
brake pads for 4-lug and 5-lug spindles:
AXXIS ULTIMATE Brake Pads - ALL AWD Turbo Mdls - FRONT $40.39 - nopi #655+0760
AXXIS ULTIMATE Brake Pads - ALL Turbo Mdls - REAR $40.88 - nopi #655+0763
4Grim
Orlando FL
I just installed my Brembos and Axxis pads on my 96 Galant and I already noticed a difference. I'll have to wait though for awhile...since there is a 300 mile breakin period on the Brembos.
sleepyvr4
Key West
looks a little better now than it did.
spoulson
Worton, MD
The caliper paint makes all the difference in the looks. I'm also surprised you were able to find affordable perfect match aftermarket rotors that weren't cheapie buttco brand. Does Brembo supply to Mitsu for rotors?
sleepyvr4
Key West
good question. I couldn't find brembo blanks for gvr4 4 lug, but I believe if you look hard enough they're out there.
Ted Andkilde
Windsor, Canada
goog question. I couldn't find brembo blanks for gvr4 4 lug, but I believe if you look hard enough they're out there.
The Raybestos PG+ rotors are apparently 4 lug Brembos in a Raybestos box -- a few board members have bought them and may chime in.
rockauto.com stocks them (or more accurately -- drop ships them) for cheap...
Cheers, Ted
sleepyvr4
Key West
are the rear spindle bearings the same on a 1g tel as the gvr4? I'm using caps and I've found part numbers for all the bearings and shields - but want to verify if possible with someone who's done this. Subframe from a 91 talon -
bearings are:
mb290175 - 16x58
mb569972 - 72x17-35
outer/inner covers:
mb393803
mb290428
dust seal:
mb393807
ok - I just cross referenced it and all the part numbers are the same for the 2 cars.
