160,000 miles on the body and about 9,000 of a fully rebuilt motor.
1/4 mile time 12.325 @ 112.38
1/8 mile time 7.949 @ 90.19
Best 60 ft. 1.819
SUSPENSION AND BRAKES
KYB AGX struts in the rear
KYB GR2's in the front
Stock springs
SP performance slotted rotors
Porterfield RS4 brake pads
Technafit stainless steel brake lines
New calipers front and rear
ATE superblue brake fluid
New front ball joints.
New E brake cables
DRIVETRAIN
ACT 2600 Clutch
ACT chromoly flywheel
Shep stage 3 transmission with spyder lock center differential
4 Bolt rear end
4 wheel steering eliminated
Pennzoil Syncromesh fluid in the transmission and tranfer case
ENGINE
Balance shaft eliminated
2G pistons on 1G rods, 190 compression across all 4 pistons
Crower valve springs and retainers in a mildly ported head
HKS 272 cams
Ported EVO 3 exhaust manifold
Extrude honed intake manifold
Forced performance "green" turbo
Tial 38 mm wastegate
Buschur racing 2.5 inch turbo back exhaust
SX fuel pressure regulator
Supra fuel pump rewired
950cc injectors
Buschur racing "Race" intercooler
2G MAS
K&N intake filter
Non cruise throttle cable
INTERIOR
AEM wideband 02 sensor
Auto meter boost gauge
Hallman in car boost controller set to 15 Psi
3G shift knob and shifter boot
Eclipse steering wheel
EXTERIOR
93 headlights
Sunroof
New all season tires with 95% tread left.
Car is tuned using DSMlink
Best 60 ft. 1.819
Stock springs
New E brake cables
DRIVETRAIN
ACT 2600 Clutch
4 Bolt rear end
ENGINE
HKS 272 cams
950cc injectors
2G MAS
K&N intake filter
INTERIOR
EXTERIOR
93 headlights
Sunroof
