WTB: Starter harness w/ triangular plug
TSimage
Sacramento
I have a bunch of plugs from DSMs with the 2 prong oval and 4 prong square plug. I however need the one for the Galant that uses the triangular connector.
TSimage
Sacramento
That's fine or it might be easier for the whole starter harnes. Just a few more inches of wire.
bradrs
Alta Loma, CA
Is it the male or female side? Is this the right connector?
You can get them new, so you don't have to reuse old pigtails. JNZ, Magnus, Extreme PSI sells them to name a few shops...
TSimage
Sacramento
It's the male side. I just need the whole harness. I don't want to splice up one of my DSM harnesses if I don't have to and in general that harness goes for about the same amount as the plug most likely.
Struc
Oconomowoc, WI
JNZ started stocking all the different connectors. Might want to give Paul a call and see if they have it.
I have these connector ends if you want one. You can de-pin the 4 pin plug and put this on. Reversible if you ever need to.
