WTB: Rear 5 lug conversion sent to australia
89jvr4
Member
sydney,nsw australia
As the title states, i am based in australia and need a NON ABS 5 lug conversion sent over etc hub setup, calipers and rotors. If anyone is able to do so, please contact me with prices and we will go from there. Thankyou
Just FYI to save on shipping costs- the calipers are the same, and you can redrill your rotors to 5 bolt holes. Alternatively, possibly some other Mitsu uses rotors the same size but 5 bolt that was sold in Aus.
ONe more- ABS/non-ABS doesn't really matter if you want non. The sensor is just installed on the shaft, but without a sensor it could be left there with no ill effect.
Theoretically, you could have a machine shop redrill the rear stub shafts to 5 bolt as well if you can't find the parts.
89jvr4
Member
Thankyou for the info mate i appreciate it. If that is the case, then i will just grab the hubs and sort the rotors out here. Unfortunately the shops around me don't like redrilling hubs as they have all turned me down, or asked ridiculous money to turn me away.
Yes, that operation does require a great level of accuracy to keep things correct.
